I'm attempting to get rid of the fuzz/noise around the edges of images on multi generational vhs tapes after I've converted them to dvd. I badly need a filter for this if it even exists. Can anyone point me in the right direction?
You could use some of the inbuilt noise filters in programs such as TMPGEnc Plus although if it is only around the edges you might consider that you won't see them when playing on a TV because of overscan, or consider cropping say 8 pixels off each side and adding black bars.
If in doubt, Google it. -
The idea should have been to remove the noise before during capturing. A time based corrector between the VHS and your computer or a camera with pass through.
Once you have the capture completed, TMPGEnc Plus! has a few setting you may want to try. Use this guide.Hello.
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 20:36 -
How do you get rid of hissing air noise from digital camera video
By johnharlin in forum AudioReplies: 1Last Post: 22nd Sep 2010, 23:24 -
Getting rid of crackling noise
By adamf154 in forum AudioReplies: 1Last Post: 14th May 2010, 07:40 -
Can't Get Rid of Noise
By EmpireStrikesBack198 in forum RestorationReplies: 6Last Post: 9th Mar 2010, 06:21 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57
