I have problems converting Avi to DVD using Boilsoft avi converter does not solve anything since the video and audio stream do not appear to be coordinated nor video quality is far from AVI original
[Movie]
Valid : Yes [AVI]
Duration : 00:01:06
Movie complete : Yes
[Video]
Resolution : 512x288
Codec : XviD MPEG-4 codec
FPS : 25.00
BitRate : 1130 Kbps
Quality Factor : 0.31 b/px
[Audio]
Codec : ATSC/A-52 (Dolby AC3)
Number of channels : 5
Sample Rate : 48000 Hz
BitRate : 448 Kbps
I have the following video +audio configuration and would like it to play on other DVD players. What can I do or what other aletrnatives have I got?
Thank you
Ok I answered myself tis question by using Winavi converter 5.8 however the original audio stream was 5 channels as stated above converted into mpeg1 I get 2 channels. Converted into DVD pal I get a VOB by I have no idea how to see how many channels the combined output is
Any further assistance will be greted appreciated
thank you
Problems with chapters in DVD authoring/audio temporarily off-sync
By nocomments87 in forum Authoring (DVD)Replies: 7Last Post: 9th Nov 2011, 09:44 -
Problems in authoring DVD
By carlmart in forum Authoring (DVD)Replies: 9Last Post: 1st May 2011, 04:48 -
Sync problems while authoring a DVD with DVD Flick
By TioSolid in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 14:21 -
FCP dvd authoring problems
By sksvideo in forum MacReplies: 3Last Post: 18th Mar 2008, 17:57 -
Problems with DVD Authoring
By Velocity_Girl in forum Authoring (DVD)Replies: 6Last Post: 27th Jul 2007, 06:34
