  1. I recently extracted the .r00-.r## files with winrar, and extracted the mpeg2 with cdmage. Every time I try to open the mpeg in ANY program (avicodec, wmp, power dvd) it will cause the hard drive to go crazy and the program will eventually stop responding.
    What is going on
  2. A-HA! Progress....
    I finally kept wmp from crashing, and got the following error:
    Windows Media Player cannot play the file. The file is either corrupt or the Player does not support the format you are trying to play.
    Anything come to mind?
  3. Banned
    Jan 2004
    Going in Circles
    Sounds like a corrupted download
    Try buying the movie when it comes out.
  4. Sounds like someone needs to stop from jumping to conclusions....
    It's a Hong Kong flick I can't get here in the states.
    canada
    Use vcdgear or vcdeasy to extract the mpg from the bin/cue file.Cdmage proly corrupted it.
  6. Thanks man!! VCD Easy worked
