  1. I got this VCD
    Ripped using ISO Buster, then repair using vcdgear, then demux using tmpgenc. when demuxing, it stop @ a certain point. I used tmpgenc to re-encode the file, still stop @ that certain point.
    Use Vdubmod to frameserve it, same thing, doesn't work.
    I even copy the .dat file to hdd, the rename, then fix it, nothing works.
    please help.
    thanks
    canada
    Use tmpgenc tools to cut the mpg where the error is and save then cut past the error and save and join the 2 parts
  3. thaks, I tried that but it keep chunking in small sizes. ~10-20mb
