Hi,
I have created 4 new templates in TMPGEnc for testing purposes. The only settings that are different between the four are the "Rate control mode" and noise reduction filter. To be specific, I set up CQ with and without noise reduction, and VBR with with and without noise reduction. All other setting mirror LordSmurf's conversion guide for mpeg-2.
My problem is this. When I load one of these templates the noise reduction filter is never turned on. For example, if I am using CQ without noise reduction, then load VBR with noise reduction, then view the settings for VBR with noise reduction, the option for noise reduction is unchecked! No matter what I do I can't get the program to recognize noise reduction as the default setting for a particular template. It always loads the template without the box checked.
Is anyone else experiencing this or does the template simply not record whether or not noise reduction should be turned on? And, yes, if it matters, I have loaded unlock.mcf.
Thanks.
Results 1 to 1 of 1
Do I need a noise filter for Senn plug-on transmitter ?
By AAC in forum AudioReplies: 1Last Post: 15th Aug 2008, 12:55 -
Chroma Noise Reduction filter for Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 09:43 -
Avisynth noise filter like convolution3d but newer?
By freebird73717 in forum RestorationReplies: 4Last Post: 18th Jun 2007, 18:03 -
Which Noise/Pixelation filter would be best for this video?
By mlong30 in forum RestorationReplies: 3Last Post: 17th Jun 2007, 18:03 -
How to emulate the Video Noise filter in premiere pro on TMPGENC Express 4?
By hanugro in forum RestorationReplies: 5Last Post: 25th May 2007, 04:11
