Ok, I'll admit that when it comes to movies/VCD/SVCD I am a relaitve newbie, but I am quite familiar with regional coding, burning, ripping etc. I have read up extensively on the topic of format conversion, and it seems quite complicated.
Background - I am trying to get PAL format SVCD to play in North America. I have a wide screen HDTV RCA scenium TV, with built in DVD player, and just bought a Phillips DVD Recorder (stand alone).
The built in DVD player will NOT play VCD or SVCD, but the Phillips will.
Whenever I try to play a PAL format SVCD, I get sound but no picture.
Now I tried to convert the SVCD to DVD, using SVCD2DVDMPG and then Ulead DVD movie factory. Now this produces a DVD image which plays fine on the stand alone DVD player, but there is no sound!
If I understand correctly, SVCD2DVDMPG produces an mpv and mpa file after processing, but Ulead only seems to convert the mpv (video) file. How do I add the mpa file to create a working dvd? Or is there a better way to convert to a viewable image, either SVCD or DVD?
Finally, since most movies seem to be released in only one format, how do most people view them? On the computer?
I have heard that many DVD players can automatically convert PAL format so that there is no re-encoding needed. Does this mean that I simply made a poor selection when buying the DVD recorder, or is my TV the problem? If it is simply the DVD recorder, I might pick up a different stand alone DVD player if it will automatically convert.
Sorry if this is in the wrong forum, but it deals with several different topics so I wasn't sure where to put it.
Thanks![]()
Results 1 to 1 of 1
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Converting PAL to NTSC error Attempted to read or write protected memory.
By VHSonDVD in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 26th Oct 2009, 07:15 -
PAL DVD to NTSC Conversion (read as much as I could)
By DW in forum Video ConversionReplies: 3Last Post: 27th May 2008, 02:42 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
