  1. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    I've got some problems installing Canopus Procoder 2.0. After installation it says USB key is nto found. Taking a look at the help file, it says, you've got to have the USB port disconnected before installing the whole thing. Any help will be appreciated. Thanks in advance!
    Did you stick in the dongle, and follow the directions?
  3. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    Do I really have to stick in the dongle?
    Thnks...
  4. Yes, I Know Roundabout's Avatar
    Jul 2003
    ...in and around the lake
    @LS:
    Ethernet (n): something used to catch the etherbunny
    Feb 2002
    Cunhambebe
    yes, u have to stick it in, and make sure you stick it in hard and good!!
    seriously, though, it wont run any time you dont have the dongle on.
  6. Member Cunhambebe's Avatar
    Mar 2004
    São Paulo - Brazil
    lol....OK, thanks anyway
