My DVD-ROM, that came in a sony rx-450 is somewhat malfunctioning. The DVD-ROM was able to play anything, a cou ple months ago. Now all it plays is normal Cd's and a select few dvds? What is the problem? THis is the "data" that i collected.
Sony DVD-ROM
(all dvds play fine in standalone dvd
and are all ntsc region 1 unless stated.)
Played
Dragonball Z dvd - Region 1,2,4 )bought in USA store.
Comp-USA DVD-R 4.7 GB - with video on it
Any normal cd. (blank, cd-rom, music cd,vcd whatever)
DID NOT play
blockbuster rented big fish
i-spy
spiderman
hulk
star wars II
stuck on you
the bourne identity
X2
it seems like the dvd rom will NOW only play non-official dvds. (all the dvds listed above are official release movies, exept that one comp usa dvd with home footage on it.)
anybody have any suggestions?
Results 1 to 11 of 11
I suggest updating the firmware for the drive. It actually sounds to me like you have a hardware or driver problem, but the firmware is a good place to start.
Cleaning? as in a cd lens cleaner thingie. (the thing similar to a vhs head cleaner?)
i dont know what firmware is maybe you can further explain?
THanks a bunch! -
Go to the manufacturers website.
Look in the downloads section
There might be a firmware driver update for your drive. -
Firmware is "like" a software (and I use this term very loosely) for an IC chip. It can be flashed for an update, but needs to be done properly, or the devices can become an expensive paperweight. because it's a permanent change (I think of FIRM as in solid) it's FIRMware. That's the best description I can give you, though someone might have a better or more accurate way of explaining it.
OK, i got an updated firmware but, i need to acsess a MS DOS in win xp pro. is there any other msdos then comand prompt in acsessories in start menu?
BEcause: The instructions iunstruct me to
""Firmware update command
Type the following and press the ENTER key at the end:
UPG5A /n G6TAxxx.HEX
-/n will vary depending on which IDE bus the target DVD-ROM drive is
configured for. Type one of the following, depending on which IDE bus
(Primary/Secondary) and setting(Master/Slave)the target DVD-ROM drive
is configured:
n=1: Primary Slave
n=2: Secondary Master
n=3: Secondary Slave""
And when i do that i get errors, so i thought it might be somthing else then command prompt.
Once again thanks for the help!
EDIT: just in case, my dvd is a pioneer dvd-116R -
I'm not a big fan of firmware update unless you have a specific reason for doing so. In your case I wouldn't. I wouldjust try cleaning it
OK,
when i put in UPG5A /2 rpc1122.HEX
(2 for secoundary master)
i get CD-ROM IS NOT PRESENT
the drive is present, i dont know why the program is not detecting it.
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
Weird DVD Burner issue
By Noahtuck in forum ComputerReplies: 1Last Post: 8th Nov 2011, 18:52 -
DVD with weird PGC structure
By lordretsudo in forum SubtitleReplies: 3Last Post: 11th Jul 2011, 06:25 -
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 18:31 -
DVD to XviD - weird question
By m_ad in forum Newbie / General discussionsReplies: 87Last Post: 20th Oct 2008, 00:38
