I have a small problem that one of you can probably help with. I have a small .avi file from a video camera that was captured with the camera on it side, so the video is sideways, Is there an easy way to rotate the video so you don't have to lay on your side to view it?
You can flip the video both horizontally and vertically using the built-in filters in VirtualDub.
That worked, not the 2 you said but there was a rotate filter that let me turn it 90 degrees. Perfect, thanks.
That was the filter he was talking about,give him full credit.
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 13:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 10:50 -
Small clip or video at the beggining of movie
By DeNeDe in forum Newbie / General discussionsReplies: 19Last Post: 3rd Jun 2011, 13:44 -
Trying to add a small intro clip to a movie file without re-encoding
By solar2504 in forum Video ConversionReplies: 11Last Post: 19th Mar 2008, 09:19 -
By solar2504 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Mar 2008, 01:53
