Hi, everyone.
I'm having a very frustrating problem with removing the previews at the beginning of a DVD. (I've searched the forum and couldn't find anything related to my problem.)
Normally, I just rip the DVD with DVDshrink and then use IFOedit to remove any unwanted titles, etc. It's usually fairly straightforward.
However, the DVD I am currently ripping has over 30 VOB files with the last 8 of them being the previews! I can't seem to find the VOB file that instructs the player to play all the previews at the beginning.
Any ideas?
Sorry if this sounds like a dumb question but I'm still fairly new at this.
Cheers
Can you find the offending file(s) in Shrink by playing each file listed? If so, you could select all the OK files to re-author.
Use vob blanker and just blank all the previews, I have done this so I
know that it works! Very simple
How to remove previews?
By maverickluke in forum DVD RippingReplies: 6Last Post: 20th Mar 2009, 23:44 -
how can i take previews off of a dvd using dvdfab
By Moonmist3207 in forum DVD RippingReplies: 2Last Post: 25th Nov 2008, 14:58 -
Trouble playing DVD after removing previews with DVDFab
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2008, 06:26 -
No Previews 8(
By palnudb in forum ffmpegX general discussionReplies: 2Last Post: 14th Jan 2008, 11:36 -
No MPG Thumbnail Previews
By LennytheFerret in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 9th Sep 2007, 11:42
