  1. Hello people, I started to use AVID and its really different interface than Premiere which I am using. I am pressing f4 button to capture but there is nothing, just a message "select a track..." or something.
    I am using CANOPUS ACEDVio editing board.
    I tryed to import some footage captured before with Premiere and AVID said "format not supported"
    Where is a mistake.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    it is all in the manual ... capture from firewire or mojo
    also -- avid xpress doesnt import that many formats at all..
  3. Thanks for reply I will try to capture via FireWire
    Just two questions:
    1. What is Mojo?
    2. My Canopus also have analog inputs- can I capture using analog input in Avid?
    Thanks a lot
  4. Originally Posted by arvin
    Just two questions:
    1. What is Mojo?
    Thanks a lot
    1. http://www.avid.com/products/dna/mojo/
    2. see #1
