using tmpgenc dvd author instead mydvd to see if it takes as much disk space. i use a 250mb file and it ends up taking over a gig. The format is 720x480 48hz mpeg1. It works fine w/ mydvd but when i try to add file in TDA it says:
Video sequence header is incorrect,
video sequence header is necessary for every GOP in a standard DVD
To fix this use TMPGEnc's MPEG Tool. Select Join/Cut tool tab. Add the file and click go. It does not re-encode the file but just fix the header.
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 08:41 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30 -
Temporal References in GOP#9733(Zer-Based)are out of sequence(0xc10b000a)?!
By Bruxo in forum Authoring (DVD)Replies: 0Last Post: 27th Jan 2008, 21:34 -
finding GOP header by opening a file in binary mode
By VBMizio in forum ProgrammingReplies: 1Last Post: 30th Aug 2007, 06:38
