I just bought a pack of DVD case inserts from Rima, specifically http://<a class="contentlink" href="http://www.rima.com/Merchant2/merchant.mv?Screen=P...y_Code=DCI</a>. I've tried printing a cover on it, but can't seem to get it to match up with the perforated edges. It gives a MS Word template, which is what I tried using, but still can't get it to match up. Has anybody used these inserts before? It says it's compatible with Neato software, which I'd be willing to purchase if I knew for sure that was true, but I don't wanna waste $20 on a program I can't use. Any help would be appreciated.
Works perfectly with Mediaface software. You have to set you printing to A4 paper.
MediaFaceII software (Neato) is a free download from their website. It is not the most current version, but it's free!
I tried MediaFace II but it didn't have a template for DVD Inserts. But I did try using the A4 setting in MS Word along with borderless printing and it did get pretty close to the perforated but not quite. I just ended up using scissors on it instead and it still looks good. I prolly won't buy any more of this paper, though. Thanks for the help anyway.
The mediaFace II has 2 DVD insert templates, one US, and one A4. You must of missed them.Originally Posted by gnslinger
D'oh! I did miss that! Just checked it and found the template, thanks for the reply.
dvd cover to icon
By pensioner in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2009, 12:21 -
cover art issue
By triggerstep in forum Newbie / General discussionsReplies: 0Last Post: 5th Sep 2008, 17:42 -
Best paper for cover printing?
By SilverBlade in forum MediaReplies: 31Last Post: 4th Jun 2008, 22:01 -
Nero Cover Designer
By kenmo in forum MediaReplies: 6Last Post: 25th Jan 2008, 10:43 -
printing DVD cover inserts
By WhiteKenny in forum Off topicReplies: 2Last Post: 8th Aug 2007, 16:56
