I have d/l 9 .avi movies for total of 14 CD's and want to burn them to Cd to watch on my DVD player...I would like to know what is the best way to this?
What Program to use?
At what settings?
etc, etc...any help with this would be very grateful...there is so much info out here that it gets very confusing...Thanks
Results 1 to 10 of 10
You are lazy. Read the HOW-TO guides on the left of this forum. You question can make a best introductory paragraph to those guide pages, man.
Tarty...thanks for the constructive sarcassim?...IALREADY READ THE ******* HOW-TO's...it is still confusing...maybe you should be more helpful and give a person the benifit of doubt when it comes to replying instead of right off saying someone is lazy.
well anywayz..
jonywinf: you want to use TMPENC to convert avi to MPEG1, this is the best program... its fast and effective.. im not going to tell you the settings cuz it is on the HOW TO > COnvert link on the left of this forum.. if you don't understand that tutorial, you shouldn't be allowed near a computer =) -
well solidsnake that was a hell of a lot more constructive and I thank you...you basically answred what I wanted to know and that is what is the best program to use...thanks again...really just posted the question thinking that there may be a better and quiker way than having to do alot of converting but I can see that I just can't get away from it...thanks
Ok, Jonywinf, you are Not lazy. You are just Too.. busy. Ok? Too bad; was about to post the From-AVI-To-VCD-Guide-For-Dummies i drafted just now then i noticed you'd already been assisted. In order to be constructive
, i'll post this piece from my Dummies' Guide in case you misunderstand making VCD is just a matter of copying MPEG file onto a CDRom.
Chapter 2: Burning S/VCD
For VCD read - http://www.vcdhelp.com/easycd.htm
For SVCD read - http://www.vcdhelp.com/nerosvcd.htm
now Tarty that is a useful response and I thank you...the burning process I have down pat...I know that They have to be burnrd from .mpg...was looking for a quicker way of converting to .mpg from .avi but I guess there isn't...now what I got to do is check to make sure that my DVD player will play SVCD's which I see are a better quality... as I said I thank you for your response.
ok, thats very nice but the how to doens't get into problems like no sound or sound in bad sync... I have hard time finding solutions to these problems.. I get no sound when encoding my avis.. how exactly to do it? encode video/audio seperatly? I did this but the .mp2 file didn't play... no sound there... also tryed virtual dubb but the quality was poor.. so how to do it?? please help me
There is really no right answer because there is too many ways to go about it. Any of the apps will get u to S/VCD compliant.
Look for past post from users who created step-by-step screen shots.
Just remember that converting from one format to another looses quality.
4 me, I'm using cce to convert divx TV shows.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
