I have Van Helsing downloaded (screener, SVCD version) iI have joined all 3 cds to one file which is now 2.1GB in size. I want to transfer this on a DVD-R to watch it on my DVD player, but the encoding using TMPGenc Plus takes like 4 hrs !!! Is this normal? My specs are below..
also try converting/burning with Nero Vision Express and it prompts me that the file will NOT fit on a DVD-R (would fit on a DVD9 which I dont have). and so it will not convert/burn.. even if i force it to squeeze onto it it will not.
I have tried TMPGenc DVD Author and it gives me error that the file is not DVD standard.. forcing me to re-encode it with TMPGenc Plus (hence the 4hr + wait). But wonce thats done, will the file size fit on a DVD-R (less then 4.7 GB)?
Is there other software I can try thats faster/easier to do this? Google search doesnt come up with many results for this conversion.. please help, I got a few SVCDs that I wanna put on DVD but im stuck !
specs:
Athlon 2200 XP + (1800 MHz)
Asus A7N8X-X 400 FSB
1GB DDR400 RAM
ATI Radeon 9800 PRO 128MB
Windows XP Pro
80 GB MAXTOR 7200 rpm
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Closed Thread
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 02:32
No warez here buddy.
