Hey all need alittle of advise. I will be building a system that will only be used for working with my DVD's. I'll be doing some video editing, backing up my DVD's, and backing up my VCR and 8mm tapes.
I was thinking of the following platforms
Intel P4 3.0c to 3.2c
AMD Athlon 2600 or Higher
AMD 64 3000 or higher
Which chip would work best.
They will all work. Some just faster than others.
Personally I would stick with the AMD's, but that is just me. The 64 will do it faster, but cost more. However it may be worth your while to look at the 64 for when HiDef editing/playback on the computer becomes common it will give more headroom.
Also, try searching. This question gets asked every week.
-Suntan -
Suntan is right any of them would work but in general if you look at benchmarking the Intel chips get better numbers in encoding. IMHO you probably wouldn't notice too much difference in real world. Make sure you have plenty of RAM (1GB recommend) and you should be set. Also a hardware encoding video card would help also. Like the Happauges.
Good luck
Y -
Not to contradict, but I have only 512mb, and I have never ran out of memory.
-Suntan -
The P4 has a slight edge with video, the AMD a slight edge with gaming. Either would work nicely though
System build help - $1,000
By magillagorilla in forum Media Center PC / MediaCentersReplies: 19Last Post: 20th May 2011, 12:55 -
Problem with fresh PC system build - unusual instability
By PartingShot in forum ComputerReplies: 24Last Post: 6th Oct 2010, 21:36 -
Video preview not working in VOB2MPG PRO new build 3.0.0700
By Joey9 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th May 2010, 15:44 -
Looking to Build a Dedicated Encoding System
By Scarpad in forum Newbie / General discussionsReplies: 0Last Post: 9th Dec 2009, 14:10 -
Type: System.UnauthorizedAccessException
By pod01902 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th May 2007, 00:21
