How-Dee!
I need an inkjet-printable DVD-R disc that is printable all the way to the spindle hole. As close as specifications will allow. Dribbling over into the hole itself. Minimal amount of lost printable area.
If you would be kind enough to link to your source, I'd appreciate that, too. Cost is not a factor, but burn quality is essential.
Thank You.![]()
Results 1 to 9 of 9
Prodiscs have no stacking ring and can be printed to the hole. Almost 200 burns I haven't had a bad one yet, that's in a standalone recorder. If you are closer to the west coast http://www.rima.com/ if closer to east coast
http://www.meritline.com/ -
Ditto.
500+ burns
less than 3 sets of ink tanks for the R200 (replaced with inkgrabber)
Also, looks like you need a self-special for the topic title
here's a good place to start
Originally Posted by Supreme2k
Well I suppose. But my first instinct was to title this thread...
[b][size=4][color=red]URGENT!!! NEED HELP FAST!!! LIVES ARE AT STAKE!!![/b|[/size|[/color|
Modesty. Sometimes it can be your friend... :P :P :P :P :P -
Thanks for the suggestions, too. I just ordered a bunch of those 'Pioneer Approved' Prodiscs as barter goods, but they weren't printables. I'll check into it.
[Theme from 'Jeopardy' playing in the background...]Originally Posted by tekkieman
Yes? -
http://calwestray.tripod.com/images/Jeopardy.midOriginally Posted by indolikaa
Here you go....
HI there,
I would also like to pitch my vote (hey better than my tent but I digress) for the Prodisc's. I'm only my third spindle of 100 with no bad burns yet (At least none that I've seen or heard complaints about)
The only thing is they don't print all the way to the spindle hole (But they get rather close. There is a few mm's (Ok, I measured there's 4mm) of clear plastic before you get into the print surface.
Other than that, they should do what you want.
kosekjm
Forgot to mention, these have all been bought from Supermediastore. Last batch was $39 for a pack of a hundred Prodisk S03 4X -r
Suggestion to make the video look better?!
By SB4 in forum RestorationReplies: 11Last Post: 18th Sep 2010, 19:14 -
Multicore suggestion?
By pardu in forum LinuxReplies: 18Last Post: 27th Jun 2010, 19:18 -
Recording from 3 Cameras (Need suggestion)
By javaclinic in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 03:58 -
External HDD Suggestion
By sohaibrazzaq in forum ComputerReplies: 6Last Post: 12th Mar 2009, 09:02 -
Suggestion for repair to LD player?
By impmon2 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 4th Sep 2007, 19:08
