the buy cd's....much cheaper....Originally Posted by Bearbegr![]()
Results 31 to 35 of 35
Alright. You just lost all respect.Originally Posted by tintytinyme
Go read some guides/articles, etc. Your question just got stupid.Want my help? Ask here! (not via PM!)
best quality vs. quantity to still get dvdish quality would be to compile a dvd project that is about 6-6.5gig in size (video_ts folder), then use 2pass or advanced analysis options with transcoders like dvdshrink or nero recode to "fit to disc" and burn all in one step. you can use these programs with fantastic results down to around 55-60% if needed. much easier and faster this way then re-encoding each mpg file before authoring/compliling. most dvd authoring programs allow you to compile up to a dvd9 size/9gigish project since they are already updated to allow for dual layer burners/blanks. then just transcode output to fit on dvd5! if you need even more quality than 45-50% gives with a transcoder, then just "shrink" by using dvd rebuilder (free), since it will actually re-encode each vob using CCE...perfect one click solution in this scenario...just takes awhile vs. transcoder, of course.
Set the video bitrate of the file to 1800
Sorry, let me correct myself. To have 12 42 minute episodes on 1 dvd the bitrate has to be set to 900 not 1800. Sorry.
Sorry, its supposed to be 900 for the bitrate for 12 42 minute episodes on 1 dvd.Set the video bitrate of the file to 1800. That is what I used and it allows you to get 12 42 minute episodes on a disk.
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 16:35 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 22:23 -
fitting four hours on 4.7 GB DVD
By cthiesen in forum Newbie / General discussionsReplies: 34Last Post: 13th Apr 2008, 17:36 -
20 Hours on a single DVD?
By Alienverse in forum Authoring (DVD)Replies: 45Last Post: 26th Oct 2007, 14:11 -
What Is The Best Way To Fit 2 Hours On A DVD?
By Anakin in forum Video ConversionReplies: 14Last Post: 4th Jun 2007, 12:52
