Hi there, I am very new to this and have not been able to track down the Info I need, can you help? Basically I want to know how I can put MPEG video to a DVD (preferably using Nero 6) so it will play in a stand alone DVD player and not just my PC's DVD player. Nero mentions something about Video TS and Audio TS, not sure how, why? If someone can point me in the right direction (lamens terms) I would appreciate it.
Results 1 to 12 of 12
you need to Author the mpeg files to DVD standard (Video_TS and Audio_TS folders) look to the left in tools section for DVD Authoring
Hey guys thanks for the help, I have used TMPGEnc DVD author, and as you say, pretty easy to use, however I still can't get the DVD I burn to work in any of my standalone DVD players. I am using TMPEnc to burn the Disc, Any Ideas as to what I am doing wrong? It works ok in my PC's DVD player.....
So you would recommend a different brand of DVD R? Would it make any difference that I am useing a DVD =R only DVD burner on my PC? My DVD standalone is multi format though, wouldn't have thought this would have been a problem.
Did you mean DVD+R? Some older DVD players won't play those (or -RW or +RW, either). DVD-R is the most backwards compatible format.
Multi format implies that it plays PAL and NTSC formats. That has nothing to do with the type of disk you're using.
Does your player play DVD+R, DVD-R or just DVD-ROM/DVD-Video? -
Thaks guys, I ave now sorted it, My DVD player is both Multi Region and multi format, so it plays DVD + & - discs. I just needed to tweek it a little. Thanks again.
How make auto-play jpg-foto-DVD for standalone DVDplayer?
By onidarbe in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Oct 2009, 04:20 -
Make MKV encoded with AVC Playable with Standalone DivX Player
By adalect in forum Video ConversionReplies: 2Last Post: 2nd Jun 2009, 23:42 -
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 16:10 -
Make old parts of PC act like a DVD standalone Recorder
By SatStorm in forum Media Center PC / MediaCentersReplies: 4Last Post: 21st Nov 2008, 03:41 -
How to make DVD using MPEG Video Wizard DVD?
By nightcat in forum User guidesReplies: 1Last Post: 6th Aug 2007, 14:52
