I'm capturing from SVHS by using a Sony TRV730 camcorder to convert the analog signal to DV and pass it on to a firewire card. In general the process works fairly well but an old post made on this board made me wonder if I would get the same results if I dubbed to a digital tape in the camcorder first. I tried it and sure enough the captures are different. For example, the comb shape of interlacing is clearly visible on the capture of the digital tape while on the analog->digital capture these areas are "smudged."
I would expect the two captures to be the very close to each other. Why are they different? Does anyone have any experience with this?
Results 1 to 1 of 1
Automatic - Programmed Capture into DV of analog source via Firewire Device
By lasith in forum Capturing and VCRReplies: 5Last Post: 12th Feb 2010, 05:03 -
Shouldn't Sony Vegas Pro 8 capture DV avi via firewire?
By brassplyer in forum Capturing and VCRReplies: 6Last Post: 11th Jan 2010, 10:31 -
Capture from Sony Camcorder/Firewire connection stopping in 4-12 seconds
By tepeco in forum Capturing and VCRReplies: 4Last Post: 16th Apr 2009, 12:24 -
Capture analog video from sony camcorder
By gthoman in forum Capturing and VCRReplies: 14Last Post: 14th Apr 2009, 15:32 -
copying analog 8mm to mac using sony digital 8 and firewire
By iampammyb in forum MacReplies: 4Last Post: 15th Nov 2008, 01:15
