I have two mpg that I have been trying to burn to dvd. I used sizzle twice but it kept crashing. The mpg's will play using MPlayer just fine. Can anyone tell me the easiest way to get these to DVD? I got as far as creating disk image in sizzle while following Galactica's tutorial...then crash. It would be easier if my dvd player supported SVCD......
"Enjoy every sandwich" Warren Zevon
you could try demuxing and remuxing the mpegs back together to repair any time code errors
that or try using toasts mpeg to svcd option
just two things that come to mind -
You can also use ffmpegx to create a DVD of the mpeg files with no menu. Put all the mpgs into a folder. Make sure you delete any .ds_store invisible files using some cleaner program like .ds_cleaner from Version Tracker and do not leave that folder open in Browser mode.
Next, use the TOOLS section of ffmpegx and select the browse button to choose the folder you put the mpgs in (you could also just choose one mpeg but that would be if it was just a one mpeg movie).
Now, click the s/vcd>dvd button and let it do it's thing. It will create what you need to burn under toast. Hope this helps.
Ice
ps: this only works on registered versions
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
SVCD 704x480 mpg stills with audio?
By jungle5150 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 29th Jul 2008, 17:28 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
