  1. I have about 11 avi´s all about 20 mins long and I want them on one dvd.
    I have tried converting all to mpeg, then joining them all and then using tmpgenc to make a dvd.
    Is this the best way or am i way off, the end result does have a small problem, the audio goes out gradually but only very slightly.
  2. Could someone please help me with this.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Dont join the mpgs after encoding,if you are using tmpgenc dvd author then add the mpgs in one single track and they will play one after the other.
