Hi,
We're getting a new 30" LCD TV soon and while the guy is here installing it I would like to hook up our computer to it as well. What do I need to set up the computer to act as a PVR for time-shifting and recording to HDD?
Do I need a TV tuner card, or can I just feed the video signal straight into a capture card or something?
Sorry, not to sure on all of this so need your help and recommendations on products etc.
Cheers
Roly
You'll need a video capture card/TV Tuner Card, A large capacity HD I would get at least 100gig. I use the Ulead Winfast TV Card and it works just fine. you also need a decent video card that will have the appropriate adapter for the TV if it has one. My Video card came with all teh adapters so it should be fine. I use the S-Video out from the card. A sound card to go to the TV or stereo. Unless you buy a surround sound setup for the computer.
Other than that you don't need much. -
You could also use a DV bridge like the Canopus ADVC-100 or 1394 to connect between the two. I've been looking for a bridge like that with both in and out in each direction so that I can record from or play to the entertainment system without having to switch cables around.
Happauage WinTv PVR 250, software concerns and advice.
By MidnightMike in forum Capturing and VCRReplies: 6Last Post: 25th Aug 2011, 11:37 -
Noob, hoping to get some advice...setting up media center pc.
By KidCastro in forum Media Center PC / MediaCentersReplies: 7Last Post: 12th May 2010, 10:30 -
Advice wanted on setting up Civic Webcam
By ahhaa in forum ComputerReplies: 3Last Post: 8th Jan 2010, 14:30 -
Need advice on setting up a home media server
By jamietallman in forum Video Streaming DownloadingReplies: 2Last Post: 7th Jan 2009, 01:25 -
Setting up a PC home media center for newbie advice sought.
By geepondy in forum Media Center PC / MediaCentersReplies: 2Last Post: 18th Nov 2007, 15:15
