    Dec 2003
    Cornwall, UK
    Hi,
    I have a file on my hard drive which is just over 1 gb in size. When I click properties it tells me it is an mpeg file, and it plays fine. I want to put this onto a DVD disc to play on my dvd player. I am happy on burning etc...but I cant see anything on the conversion guides for MPEG to DVD. Am I looking for the right thing..??
    Any help would be greatly appreciated.
    Regards
    Mac
    Thanks.....Mac
    Mar 2004
    London
    The mpeg needs to be 'authored' to a dvd compatible disk before it can be played in your set-top dvd player. Check out the various guides available on this site.
    https://www.videohelp.com/author
  3. Originally Posted by deckard8
    That is of course assuming it is a DVD compliant mpeg in the 1st place!
    https://www.videohelp.com/dvd
    I suggest you use bitrate viewer to find the properties of your mpeg.
