  1. Help me get back my favorite VCD-making programme, VCDEASY!
    Pc was in the shop getting an unwanted overhaul... Now its back, and I re-installed VCDEasy (from my old 1152 version), but it won't recognize my CD-R burner/drive now.
    It said WNASPI32 was missing (which it wasn't), so I downloaded it and put it in the SYSTEMS folders anyway. Now...
    Says it might have problems with the ASPI Drivers...?
    At the end of the day it just won't burn - It'll only simulate.
    Anybody got any idea what it is I need, where I can find it, and what I do with it when I have it??? Any and all info would be appreciated, thnx.
    Doc, AKA dalek7
    www.vaughn-media.com
    Mar 2004
    London
    Download and install the 'Compel' aspi drivers from here :>
    (scroll down to bottom of page)
    http://www.avlandesign.com/007mp3ag.htm#downloadaspi
  3. Thanks very much. I'll give that a shot.
    Just the Compel drivers....?
    Will those self-install, or do I need to do anything special with them to make sure they work right/are correctly placed?
    Thanks Again...!
    Doc, AKA dalek7
    Mar 2004
    London
    Just the Compel ones. These use the aspi drivers known to be the most compatible/stable. The package will auto-install, but you will need to reboot , then check with the 'aspi check' tool which should now be in your start menu.
  5. It worked!!! You rule...
    Thanks again!
    Doc, AKA dalek7
