I couldn't find any guides for AVI to WMV so I decided to ask here. Is it possible using TMPGEnc?
I want to keep a decent quality, yet make it a really small size so I can put some up on a website. I also have the XVID codec, but wouldn't WMV be better for lower compression?
When I want to compress an AVI video file, I usually just select 'Video-CD-->NTSC" and just use the default settings. But the file size is still pretty big then. What other options/settings would help compress besides lowering the bitrate?
Originally Posted by Namie
If you you re-encode, you lose quality. Period.
If you compress further than it is already, you lose quality. Period.
To produce WMV format files, you need windows media encoder, available for download from MS. -
I found this in a Google search: http://www.riverpast.com/en/support/tutorials/convert/avi/wmv.php
How to make an AVI better quality (keeping output still as AVI)?
By Dogpoundz in forum Video ConversionReplies: 15Last Post: 22nd Sep 2011, 00:12 -
compress AVI file for future editing with minimal loss of quality
By samoyed in forum Newbie / General discussionsReplies: 4Last Post: 9th Feb 2009, 02:53 -
How to get large avi to fit on dvd while keeping quality
By BrettO in forum Newbie / General discussionsReplies: 6Last Post: 3rd Oct 2007, 08:54 -
[Help] avi to wma keeping avi quality?
By Riddick51PB in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 18:13 -
converting .avi (divx) to dvd and keeping original quality...
By RushMaster in forum Authoring (DVD)Replies: 15Last Post: 22nd May 2007, 14:47
