currently using Mydvd, which probably isnt best out since i dont see anyone else mentioning it. but i used a 200mb file to burn on dvd. It ended up at 1.7 gig total which means 1.5 gig is just for the menu and button.
Is that the case w/ most or all software, takes up over one gb just for menu and one button.
how much space does background image menu and buttons take for the programs that you all use?
What was the 200mb file ? If it was a DVD compliant video file with AC-3 audio, then this would seem excessive. If it was a 200mb Divx file, then MyDVD has to encode it as DVD compliant video and audio (and probably LPCM audio at that), which would take up a lot more space.
yes it was an xvid avi. so if i encode it to dvd compliant 720x480 in tmpgec, then will it be less space?
Menu button won't highlight
By mattblack in forum Authoring (DVD)Replies: 3Last Post: 21st Oct 2010, 18:45 -
menu button didn't work
By pcb in forum Authoring (DVD)Replies: 6Last Post: 13th Oct 2010, 16:07 -
DvdAuthorGui menu Button
By sambat in forum Authoring (DVD)Replies: 7Last Post: 15th Mar 2010, 08:04 -
Edit dvd menu button
By canaQ in forum Authoring (DVD)Replies: 8Last Post: 24th Feb 2010, 08:13 -
Menu button just starts video over
By Qun Mang in forum Authoring (DVD)Replies: 7Last Post: 13th Sep 2008, 17:06
