  1. On this mac. The computer won't read wmv files or avi so I need to find a mac program that can convert avi or wmv to mpg so I can watch what I downloaded. Is there any program like that?
  2. Moved to the Mac forum
    /Moderator bugster
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    mencoder based apps can handle that
    for the .wma give ffmpegx a try
    you could also do that for .avi but you may have an easier time with mpeg2works for the .avi
    will they play in MplayerOSX?
  4. Member Flarch's Avatar
    Apr 2004
    E68°50'15.2" S49°11'12.6"
    ffmpegX seems to transcode .wmv minus the audio.
  5. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    For avi files I use Quicktime Pro. I've dl codecs for QT that allow me to view almost all types of avi files; however the audio is typically mp3 so I use another program for the audio. FFmpegX does the trick with the audio, but typically fails with the video.
    There is another program currently in alpha stages that handles both perfectly, but I think that the software maker is sitting on it for a little while.
