hey fellow encoders,
I have a quick question,
is it possible in dvd lab or dvd lab pro. to create a motion menu that if I create a 20 or 30 video clip and then have the buttons appear after the clips ends and ends up at the starting frame? if so, how do you do it?
thanks for any help.
sincerely,
schunn99
yes, it is very easy actually. Just drag the loop point in the menu. This is the exact point the menu links will appear and of course where the menu loops to after the first play. Just above your motion video track there is an "L" drag that to where you want it, that is your loop point.
note: make SURE you have the latest beta version, beta7 at time of writing
Vegas to DVD Lab Pro motion menu issues
By outerspacerace in forum Authoring (DVD)Replies: 4Last Post: 23rd Jun 2008, 21:28 -
One Cell Motion Render in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 23rd May 2008, 10:07 -
Delayed Links, Motion Menu and DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 14Last Post: 30th Apr 2008, 02:33 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 13:03 -
how to make motion menu in dvd-lab pro that like this
By 741210 in forum Authoring (DVD)Replies: 10Last Post: 23rd Aug 2007, 23:53
