  1. When I compress a 22min video it results in a 26 min ...
    What the hell ?!?!?!? I really don't understand.
    My Mpeg2 file is 544x576 25fps PAL 8Mbit/s and I encode 352x576 25fps PAL 4MBit/s ....
    What can I do ?
    Thanks!
    Check the source range(double click on Source range under Settings->Advanced)...it might be some black empty frames at the end, if so then just move the end positition if not then uninstall that codec and try the other mpeg2 codec or use this method http://www.vcdhelp.com/mpeg2tovcd.htm
  3. The other method doesn't work because DVD2AVI 1.74 crashes.
    Both codec have the same problem (22min become 26min) without black at the end... The video seems to be played slower, so 22min become 26 ...
    very strange. My source is captured with Hauppage DVB in PVA format, and the converted with PVA Strumento into Program Stream Mpeg2 ....
    I don't know what to do!
