I'm switching over from tmpgenc to CCE, and I can't seem to find a setting where I can specify resolution. Anyone know where it is? I'm using CCE SP demo.
I made a script, but it crashes CCE when I try to load it. I tried playing the avs file in windows media player, and it crashes to, but will still play the file.
Use FitCD to write the script for you, easier and more reliable.
Just load the AVi file with FitCD and save the script. It has some nice options as well.
If the file does not play error free in Windows media player it is not going to be accepted by CCE either. -
I uninstalled CCE SP v2.5, and downloaded CCE SP v2.66, and it can open, and encode the avs file no problem. I did some research, and found that v2.5 has a problem with athlon processors, and that audio has to be specified in the script file (even if you don't have any).
CCE Luminance setting -- clarification needed
By eclipse95 in forum Video ConversionReplies: 14Last Post: 30th Sep 2009, 11:12 -
Problem setting monitor resolution
By gll99 in forum ComputerReplies: 5Last Post: 16th May 2009, 08:17 -
Setting up default option for ripbot lock size and resolution
By Syco54645 in forum Authoring (Blu-ray)Replies: 0Last Post: 15th Dec 2008, 18:33 -
deciding on the correct resolution setting when converting to mpeg2
By Dreadnaught in forum Video ConversionReplies: 4Last Post: 15th Jan 2008, 09:36 -
Is there a jerkiness (motion detection?) setting in CCE?
By robrosen in forum Video ConversionReplies: 0Last Post: 20th Sep 2007, 17:42
