Hi!
I made simple switched menus in DVDlab pro, and while it works perfectly on the PC, when played on a standalone player, the following problem comes up:
On the PC, clicking on the menu item plays the movie, as it should, but on the standalone player it acts like the down button was pressed, and it jumps to menu 2.
How the hell could be this possible?
I'm using DVDlab pro, and while i love the freedom it gives, unexplainable problems like
(creating 4 menus with different background, and after authoring the second and first menu's background becomes the same...)
makes it not too usefull....
Anyone?
NEVERMIND!!!!!
I'm just a d*mb*ss, and i shouldn't burn DVD's 2'o clock in the morning....
...i forgot to set the 'first button' on the first menu. (so it still works on the PC because it disregards 'auto action', but not on the standalone)
at least i'm happy it's my fault and not DVDlab's....
As per the changing background problem, that was real, and i had to redo the menu, and the problem disappeared. When i compared the working and the not working versions of the project files, i found no difference (when loaded the menus looked the same), so it must be the problem how DVDlab keep track of it's files (deleted.lib and other stuff).
So an advise: NEVER DELETE ANY BACKGROUND/OBJECT/PICTORE...etc files from DVDlab's directory manually, use DVDlab to delete them (even if it takes more time)
THX,
Edo
Music in your DVD Menu's with DvdLab Pro
By RickyPinxt in forum Authoring (DVD)Replies: 5Last Post: 8th Apr 2010, 17:45 -
One subpicture overlay across menu cells? - DVDLab Pro
By nostrum in forum Authoring (DVD)Replies: 0Last Post: 8th Feb 2010, 10:36 -
DVDLab Pro Menu Text Disappearing
By C0SM0 in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2009, 16:33 -
DVDLab Pro Menu Structure Questions
By raouliii in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2007, 21:32 -
DVDLab PRO - Music in Menu
By poutniksantiago in forum Authoring (DVD)Replies: 8Last Post: 15th Nov 2007, 07:28
