as you can see, the duration is almost 5 hours, but i cant seem to seperate the Theatrical and the extreme cut apart. (i want to keep the theatrical version, which is Title 2). so i want to delete Title 1.
is there any way i could do this?
i tried InstantCopy, but when i de-select Title 1, it also unchecks Title 2, it's like they both have to be included.[/img]
but that leaves no menu. and i want the menu with all extras, AND the theatrical cut. deleting the extreme cut will require less compression.
Try using BobVlanker. It alows to select the titles to blank, individually.
Newbie to DVD backup -
I think your running into "seamless branching" were two versions of a movie are contained in the same VTS and identified as PGC's within the VTS. Just de-select the streams you don't need. Set to 4478MB's and let DVD Shrink go. I had the same "problem" when I backed up the Alien Quadrilogy Set.
You can delete unwanted streams in DVD Shrink full backup mode. I do it all the time. I normally do full backup with menus and keep only the first audio stream and no substreams.
Originally Posted by wulf109
everyone knows you can remove unwanted audio streams in shrink.i do this all the time aswell. but he has two versions of the movie on the one disc and he wants to remove one copy being audio AND VIDEO. you can not remove and video stream in shrink without re-authoring or replacing it with a still image and that is still NOT removing it. however you can ver easily remove/delete it with dvdremake and that is what i have done with the exact same type of setup this dvd is.
Terminator on DVD & Bluray, anyone own both for an audio comparison ?
By Noahtuck in forum Newbie / General discussionsReplies: 19Last Post: 3rd Apr 2015, 15:28 -
Total Media Extreme makes coasters when creating DVD-AVCHD
By edong in forum Authoring (Blu-ray)Replies: 2Last Post: 29th Mar 2010, 13:53 -
Terminator 2 Official dvd drm wmv files
By BIFFtheSTIFF in forum Video ConversionReplies: 5Last Post: 18th Nov 2009, 14:15 -
Terminator Re-Booted
By videobread in forum Off topicReplies: 3Last Post: 1st Oct 2009, 09:47 -
Terminator Vision
By Squid_uk in forum EditingReplies: 16Last Post: 17th May 2009, 14:57
