Results 1 to 10 of 10
  1. ok, i got a movie from IRC and i want to put it on a dvd. i extracted it, but when i try to convert it the folder doesnt contain any video files. how do i make the file convertible? sorry if this is a dumb question.
  2. You might want to tell ua what IS in the folder
  3. sorry..i figured it out but i have another problem.....i extraced the bin from the disc 1 folder using isobuster but i cant figure out how to extract the bin from the disc 2 folder. it doesnt contain a .rar file (which i normally extract to get the bin). i check other movies that i dloaded and none of them contain .rar files in the second cd folder. so basically, i can convert disc 1 but not disc 2. help, please.
  4. SVCD usually 2-3 disc. (1.5-2gig total) . You probably downloaded only 1 disc(around 700-800mb). Check how big is your files. If ithe file is only 700-800mb that mean you only downloaded 1disc.
  5. i down loaded it as one file (1.5G) but when extracted it contains two folders, disc 1 and disc 2. i can only get the bin for the disc 1 folder, disc 2 doesnt contain a .rar file
  6. IF your have 2 folder, then what are the files in the disc 2 folder? And how many files and size of the files are in disc 1 folder?
  7. what program do i need to take a screen shot so i can post what i have?
  8. Originally Posted by spmurph
    Printscreen on your kboard will take a screencap... paste in image editor and crop / size to you needs.
  9. thanks.... theres a .rar file in cd1 folder
    but not in cd2
  10. can you guys see the pics?
