I followed all the recommended steps from the sticky tips. Here is my configuration on WinXP Pro:
- Sony DRU510A as secondary master. Liteon 54426S as secondary slave
- at BIOS, changed the secondary IDE (master and slave from AUTO to UDMA100). Mobo has VIA KT266A chipset
- Device Manager shows Seconday IDE Channel on UDMA if available and using Ultra DMA Mode 2.
- loaded latest ASPI driver (4.72a)
- Sony DVD drive has latest firmware (1.1a)
After all these steps, when using DVD decryptor or SmartRipper, the ripping speed is around 2X. With DVD decyptor, I changed in Tools/Settings/Device tab/Options to Read at Max Speed. And it still reads at 2X.
Any ideas??
Results 1 to 13 of 13
Sony offers a drive tool "DSS4DRU.exe" that will speed the reads of your drive up. I didnt read any previous posts so I dont know if you tried this yet. In overdrive mode you can rip dvds much faster.
http://sony.storagesupport.com/legalagreement.zulu?dlid=dvdrw/downloads/dss10/DSS101.zip
try it out maybe it can helpI have a small l*enis -
Originally Posted by copiador"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
I will try the DSS4DRU. Strange that other people got high ripping speed without using extra software.
Before I bought the Sony DVD burner I used Creative DVD-ROM 12X. Even this drive reads at 2X when using SmartRipper. That was 2 years ago. It was the same mobo, bios version, but with win98se.
Very strange -
Nearly ALL DVD burners rip CSS encrypted media @ 2x. The only workaround for this would be to use a hacked firmware (or a small utility like someone posted before).
Originally Posted by DaveS
The burner does not go through any more strain by ripping than burning a disc. Dave, I suggest you study up more on computers, before you make stupid statements like that.
You can use the burner to rip and burn. -
hey gitreel -
well at least you're living up to your reputation
https://www.videohelp.com/forum/viewtopic.php?t=231892
anyway, all I was really saying is that most burners don't seem to rip that well and I don't think I've seen that much on getting them to run quicker - maybe firmware hack as per above or maybe it's something else that can't be hacked, I don't know.
If you've got a dvdrom, it just makes sense to rip w/ that..any burner's got a certain # of hours until it fails..maybe none of us will ever get there but if you're doing tons of ripping, you'll get there sooner."As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole." -
However, I never could get mine to rip any faster than 2x when I tried. So I do all my rips using a Sony 1611 reader flashed to RPC1. Fastest I've ever seen it go was 15.2x when ripping DVD5's w/ DVDDecrypter.Like a flea circus at a dog show! -
Try the Pattin Couffin device drivers. You may get a speed increase.
http://www.mtc-comp.com/vso/patin-couffin_setup.exe
Install them then >
In the settings of DVDdecrypter > I/O tab
select Pattin Couffin.
My rip speed in increased about 4x with these. -
Imgburn getting stuck Burning DL Dvd+R
By Amzin in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2010, 16:33 -
DvdShrink process stuck after burning to dvd .
By fibola in forum Authoring (DVD)Replies: 8Last Post: 19th Sep 2008, 11:17 -
Burn A dvd from AVI. and stuck in the middle
By jtish in forum DVD & Blu-ray WritersReplies: 15Last Post: 5th Jan 2008, 16:43 -
DVD Stuck
By tvlreject in forum DVD & Blu-ray WritersReplies: 15Last Post: 2nd Dec 2007, 20:39 -
I'm stuck.... can't get *.mpg authored to DVD
By la7oea in forum Authoring (DVD)Replies: 2Last Post: 17th Oct 2007, 13:17
