i have a ntsc dvd and a pal dvd that i want to put on one disc using tmpgnc dvd authour but it wont let me put both formats on the one disc, can anyone tell me a good freeware ntsc to pal converter so i can get round this problem![]()
Results 1 to 29 of 29
Hello,
Read this thread for help on your problem --
https://www.videohelp.com/forum/viewtopic.php?t=232563
Kevin
Hope this helps.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
excuse my lack of knowledge but i need to convert one of the programmes to pal so i can authour them in tmpgn dvd author
canit be done with a simple program ??? and if so what is it
im alittle confused, isnt there a straight forward program that can just have ntsc input and provide a pal output
sorry to sound so dumb
If you want tip top results use tmpgenc, takes forever but great quaility.
I have obtained satisfactory, even great, results using Power producer gold 2 by cyberlink, I think this type of all inone software has an encoding engine?
Anyways, you start this software saying you want pal or ntsc, import the file, and then just proceed, it takes a while but no where near as long as tmpgenc.
You then import the resulting mpg file into tda and the ntsc file you already have and away you go.
Good luckPAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
no. and converting isn't authoring so I'm moving you.Originally Posted by efiste2
how do i import my NTSC files (which are in the form of a videoTS and audioTS files) into tmpgnc , when i start tmpg it wont recognise these files.
i use tmpg express and author, both can import dvd files to "re-edit" them.
In express you use the sourec wizard, in cyberlink power producer it is a bit flaky I have got it to work but the way it does it, from dvd disk only, not from HD !, is odd, IMHO.
Again good luck. You are treading a path well trodden.PAL/NTSC problem solver.
I haven't tried it, but PowerProducer 2 Gold seems to have that capability. I'd try it, but I have no way to check the end result since I don't have a PAL capable TV or DVD player. -
There are programs that will identify the finished product for you, indeed you can re-load the finished dvd into tmpenc/tda/ and if you try to play it on your equipment and it rolls or doen;t play at all you've probably done it correctly!
Okay- I just put a 2 minute NTSC mpeg-2 into Power Producer and output a PAL DVD. It played on the computer (as expected) and when I tried to play it in my standalone I got the message "disk can't be played due to area prohibitions". I really didn't expect that since the disk is region free, but apparently it did output a PAL disk.
I also made a disk image on the HD from an NTSC DVD, mounted the image and then loaded that into PP2 and output an PAL disk. Same results.
So it does seem to work, but I'd try the 30 day trial first if you don't already have PP2. -
i have the project wizard but it still wont let me open the files
No, is is the source wizard that I use, not project wizard, sorry.
Tell me how large are these "Files", you know what I wish we could email stuff to each other but I guess the speed of high speed internet does not allow for 4.7gb files to fly around!
source wizard wont either, i must have the files saved wrong!!! DOH how do i extract the NTSC DVD into the right file type. at the moment they are a video TS and an audio TS file wich include vob,bup etc etc how do i extract into an mpeg file so i can get tmpgnc to recognise it, i relayy appreciate everyones help with this, and pardon my naivity
efiste2; Sorry to leave you hanging.
DVD2SVCD is supposed to automate all of this. It uses TMPGEnc as the encoding engine.
You just install DVD2SVCD and TMPGEnc, and then point DVD2SVCD to Tmpgenc (in its config), then use DVD2SVCD and it will massage the files into the appropriate format and call TMPGEnc when necessary to do the encoding. -
RIGHT now im getting somewhere, ive pointed dvd-svcd towards tmpgnc and loaded in my file but i cant tick the ntsc to pal option!!!!! anymore help my friends
I'll have to leave that to someone else; I don't have DVD2SVCD and it is a 8mb download.. and I am on dial-up.
One thing, though; make sure you are going the right way.. If you are in North America or Japan, your television is NTSC and you want to convert the PAL video. If you are in South America or Europe (or Australia, or many parts of Africa..), your television is PAL and you want to convert the NTSC video to PAL. -
Open the Video_TS Folder with DVD Author (use the Add DVD video button). After clicking OK to get to the Option Settings, check the box that says 'Copy the clip video data to the HDD'. (Before click OK you can select where the clip is copied to). Click OK and it will copy the video to an mpeg-2 file. -
i think id better start again, I have an NTSC dvd and a Pal dvd, i need to put the to discs onto one and use tmpgc dvd author to create the menus and chapters,as you know tmpg dvd authour wont accept the two files together so i need to convert the ntsc one into pal, what can i rip the ntsc one with so that tmpgnc will allow me to convert it, thats assuming that tmpgnc will let me do that? sorry to have to start again but im gettin lost with all this help (i really do appreciate it),
Converting one format to another is a real pain in the a$$. That has GOT to be the most common question asked here on these forums.Originally Posted by efiste2
One way- step by step:
Use Power Producer 2 Gold to open the NTSC DVD. Set PP2 to output to PAL) of the other DVD. Process that file to create a set of DVD files on your HD. Wait until done.
Close PP2 and Open TMPGEnc DVD Author. Import the DVD files created by PP2. Import the DVD files from the PAL DVD. Create menu, create DVD, watch DVD. -
im using pp2 gold trial (didnt want to buy it until i know it works) but i cant find the option to set it to pal output! could you tell me where this option is?
Open the program. On the first screen click on Produce Movie Disk. That will move you to the 2nd screen.
On the 2nd screen there are 5 boxes with selectable options. Those are:
Location, Video Recording Format, Disk Capacity, Video Quality and Audio Quality.
You can select PAL or NTSC in the Location box.
NTSC to PAL Converter and Vise Versa
By rockonvidtrade in forum Authoring (DVD)Replies: 14Last Post: 8th Apr 2013, 18:28 -
how to test Pal/Ntsc converter box?
By spiritgumm in forum Newbie / General discussionsReplies: 0Last Post: 4th Jun 2009, 11:28 -
PAL-G to NTSC converter
By whizzkid in forum Newbie / General discussionsReplies: 0Last Post: 11th Jan 2009, 19:30 -
is there any PAL to NTSC DVD converter?
By mvp in forum Newbie / General discussionsReplies: 4Last Post: 30th Oct 2007, 00:38 -
Anyone Ever Heard of Digital Media Converter Pal to NTSC
By mn072065 in forum Video ConversionReplies: 5Last Post: 9th Jun 2007, 22:50
