Hi. I have started using DVDs for backing up files, and I use -Rs because they are the same ones I use for video, but I have a writer that does both, so I was wondering if one was better than the other for files and other uses where it doesnt matter if it will work in a standalone DVD player.
Doesnt really matter as long as the pc's your using them on can read the format.
you may find a small amount of really old dvd drives that may not read both. but for the most part the majority of drives will read them w/ no problems
For general users, either media should be adequate for any form of usage. Granted, I have had more success in backing up movies on DVD -R, that is NOT to say that it is better. Just my personal observation. For just general files, it really doesn't matter. If you are going to use it for other sources, xbox, ps2, movies, some are more finicky than others. From what I understand, businesses usually use dvd +r b/c it has better error correction.
Here is a short blurb on the media format differences from videohelp:
DVD-R and DVD-RW
DVD-R/W was the first DVD recording format released that was compatible with standalone DVD Players.
DVD-R is a non-rewriteable format and it is compatible with about 93% of all DVD Players and most DVD-ROMs.
DVD-RW is a rewriteable format and it is compatible with about 79% of all DVD Players and most DVD-ROMs.
DVD-R/W supports single side 4.37 computer GB* DVDs(called DVD-5) and double sided 8.75 computer GB* DVDs(called DVD-10).
These formats are supported by DVDForum.
DVD+R and DVD+RW
DVD+R/W has some "better" features than DVD-R/W such as lossless linking and both CAV and CLV writing.
DVD+R is a non-rewritable format and it is compatible with about 88% of all DVD Players and most DVD-ROMs.
DVD+RW is a rewritable format and is compatible with about 79% of all DVD Players and most DVD-ROMs.
DVD+R/W supports single side 4.37 computer GB* DVDs(called DVD-5) and double side 8.75 computer GB* DVDs(called DVD-10).
These formats are supported by the DVD+RW Alliance.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 04:03 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
