ONLY once in a random blue moon will my XP Pro system recognize my Canopus ADVC-50 when I plug it into the embedded TI IEEE 1394 adapter onboard my Abit IS-7 mobo. The rest of the time it REFUSES to recognize it at all!
I've downloaded and installed the "1394Filter" from Canopus, and it worked ONCE immediately thereafter, but it never worked again! Windows simply won't show that a capture device is connected at all. "Add New Hardware" wizard doesn't recognize it either.
What is the problem? What can I do? How do I work around this?
System: Abit IS-7. 3.2GHz P4. Running XP Pro SP1.
1G Crucial DDR-400 PC3200 RAM
LSI Logic LSI20320-R UltraSCSI 320 adapter
1 WD Raptor 73G 10krpm SATA-150
1 WD 120G 7200rpm SATA-150
1 Seagate 73G Cheeta UltraSCSI 320
some other abit and also epox boards seems to have this problem ..
try to install a firewire card (they are not expensive) .. ads is a good brand .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Try a PCI 1394 card. They aren't very expensive. Some onboard 1394 setups have problems with those type of devices. Have you tried it with other Firewire devices such as a video camera?
Other than this, go to the motherboard manufacturer and ask them why. -
I had this same problem with my new Dell system. I contacted Canopus support and they provided some 1394 drivers. After that my ADVC-50 always comes up.
Try that and see what happens.
Jim -
Ditto... my Fasscom MB with onboard 1394 was a tad flakey with both my TDK DVD Burner and SonyDV..... So... disabled and purchased a ADSTech 1394 card... works like a champOriginally Posted by redwudz
Contact Canopus tech support (via email). It might take a couple of days for a reply. They will send you update 1394 drivers and instructions on a fix.
I had same problem and this was the fix.
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Best Practice with ADVC-1394
By kjfrey55 in forum Capturing and VCRReplies: 1Last Post: 12th Feb 2010, 02:15 -
Laptop IEEE 1394 doesn't recognize camcorder
By NautTboy in forum Capturing and VCRReplies: 4Last Post: 21st Jan 2010, 21:15 -
Capturing with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2009, 22:55 -
Canopus ADVC-55 vs. ADVC-110
By bcags7 in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2008, 16:15
