i used dvd shrink 3.1 to decrypt badder santa then open it up and re-authored just the main movie like i usually do, in the compression section it shows AC3 5.1 ch English and its checked, but when i hit back up again and it saves the files to my hard drive there is nothing in the audio_ts folder, and when i burn the files onto a dvd i get no audio. if i take the re-authored files and open them in to dvdshrink it shows AC3 5.1 ch English in the audio section like it has audio. any ideas on why im not getting audio when i burn it? thanks
-Allan
All the DVD files need to be in the video_ts folder. There will be nothing in the audio_ts folder.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
Need help with burning DVDs (audio related)
By JediMindTrick in forum Authoring (DVD)Replies: 3Last Post: 29th Mar 2010, 19:10 -
help burning dvds
By bunty90 in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 13:53 -
the best burning speed for DVDs
By JohnnyBob in forum Newbie / General discussionsReplies: 13Last Post: 15th Jan 2008, 09:50 -
burning dvds
By terrie29 in forum Newbie / General discussionsReplies: 7Last Post: 7th Oct 2007, 19:08 -
Burning HD DVDs...Help!
By Anonymous55 in forum Authoring (DVD)Replies: 6Last Post: 14th Jun 2007, 21:37
