Is there a way to set the divx codex to do a 2 pass encode without having to go back to set it up for nth pass. IE Do a 2 pass encode in one step.
Thanks Barrybear
Use Gordian Knot as your encoder. You can do up to seven passes in one shot. Here is a guide to using Gordian Knot:
http://www.doom9.org/index.html?/gknot-main3.htm
If you find this a little daunting (as I did when I first used it), you may want to give AutoGK a try. This will also allow multiple passes with only one setup.
Hope this helps,
Cobra -
Thanks so much for the reply.
I am using Virtualdub to edit out the adverts of an avi file and converting to divx in one go. This is why I would like to be able to set the codec up to do just 2 passes.
Barrybear -
Use the Batch mode in Vdub.
Set your first pass parameters in divx codec, then in vdub select Save As AVi, give a name to the file and check the box "Don't run this job now; add it to job scontrol so I can run it in batch mode".
Set the parameters sfor the nth pass and do the same as above.
When ready, go to File->Job Control. In the new windows click on the "start" button. -
Just to add to what cd090580 said, when you are in the Job Control window if you select Options-> Shut Down When Finished (or something like that) the computer will power down when Vdub is finished encoding. Useful if you set up a couple of passes and let it run while you sleep.
Also, you can set up more than one movie at a time, just make sure each movie (both passes) are done together.
EX:
movie 1 Pass 1
movie 1 Pass 2
movie 2 Pass 1
movie 2 Pass 2
etc.
etc.
Very useful for a marathon encoding cycle (if you are going to be away for the weekend) or if you backup something like a TV series.
-Suntan -
Thanks for the help . That would seem to be the answer.
Barrybear.
Virtual Dub 1st & 2nd Pass Encoding
By OrchestraAndChoir in forum Video ConversionReplies: 10Last Post: 22nd Jul 2012, 07:20 -
virtual dub não abre arquivos cokm codec xvid
By sandroguchilo in forum AudioReplies: 3Last Post: 14th Dec 2010, 16:43 -
ffdshow codec not showing up in Virtual Dub
By uglijimus in forum Video ConversionReplies: 2Last Post: 8th Mar 2010, 15:12 -
virtual dub xvid codec encoding w/o profile
By caner12 in forum EditingReplies: 7Last Post: 5th Jul 2009, 12:08 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 17:47
