I got a problem with converting my .avi to .wave.. When i want to save as .wave it says the audio compression is not compatible with the input format..
I have never had problems with virtualdub..
But when i check the file info at 'file compression' it says 'unknown' i guess this is the problem. But want to know how to convert it now? CAN ANYBODY HELP ME....IN ANY WAY?
An AVI file is the video and audio, a wave file is just audio. If you wan't to save a wave file from virtualdub, then open up your avi, file>save wav. This will rip out the audio to a new file. If your doing a divx movie theis "wave file" will actually be an mp3 (probably) and so will need decoding by something like CDex or Lamer to make a true wave file. You can tell what format the audio is by looking at file>properties in vdub.
virtualdub capturing
By cesar110 in forum Capturing and VCRReplies: 1Last Post: 7th Aug 2011, 00:17 -
AVI to WAV in Virtualdub
By crumbworks in forum Video ConversionReplies: 20Last Post: 9th May 2008, 05:10 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Virtualdub capturing resolution problem
By bloodshed in forum Newbie / General discussionsReplies: 3Last Post: 15th Jan 2008, 13:07 -
capturing audio on PC to MP3 or WAV format, which software ?
By ktnwin in forum AudioReplies: 3Last Post: 2nd Nov 2007, 05:13
