Finally got my toast 6 and I want to burn a backup dvd that I rip using Mac the ripper and everytime I drag the file to toast and click burn, it will indicate that it doesn't have enought memory. What shall i do? By the way I have a G4 MDD with 512 MB memory. My Toast is set to dvd-rom UDF.
The drive where my toast reside have 49 gb and the drive where the file is located have 91 gb. My file is only 4.18 GB so I know it should fit in the dvd. It doeesn't even work when creating a disk image.
I did an experiment where I rip only a chapter of the dvd and was able to create a disk image. Is there any settings that I may have missed?
Toast 7
By JordanBlake in forum Newbie / General discussionsReplies: 0Last Post: 7th Jun 2010, 15:07 -
Alternatives to Toast
By danielmak in forum MacReplies: 6Last Post: 16th May 2010, 23:37 -
Toast 10.0.2 question
By danielmak in forum MacReplies: 1Last Post: 10th Jul 2009, 08:24 -
Toast 9
By lawnman in forum MacReplies: 1Last Post: 11th Mar 2008, 22:45 -
Toast 8.0.3
By lawnman in forum MacReplies: 1Last Post: 17th Nov 2007, 06:00
