Hey guyz...
I have to reboot my computer after I burn a dvd all the time. Its annoyingAny of you Nero dudes know a solution for this?
I have pioner 107 DVD Burner, using an Athlon 64 3200+, 1 GB ram, Win XP SP1 32bits and Nero 6.1.3.6
When finish to burn the second movie a message appears (when Nero is closing it) and just said "Unable to finish the process". If I restart windows and try to burn the same movie again the same error pops-up, but if I turn my computer off and then turn it on, I can burn it normally.
I don't have any problems to burn the first DVD, my problem is the second one. It's like if the PC (Nero) is taking all the resources the first time and when it's trying to do it again, it can't.
This is just killing me so if any one can help I would be so so happy...
Thanks,
Have just started experiencing problems with my Memorex Dual-x burner.
using elby's CloneDVD I have been making back ups with no problems, until I tried making back ups of Simpson's, and, Vin Diesel's XXX. Simpsons Season 4, disc one, using TDK 4x DVD-R, turned out ok, though, after the federal/interpol warnings, and, the fox disclaimer, it stops, though if you hit play a couple times it goes on. But since then using Memorex 4x DVD+R, and, Khypermedia 1-2.4x, it doesn't seem to burn, though CloneDVD says it has. Checked the supposed burned disc, using DVDinfopro, it says it appears blank. Is it my burner? the program? or, do i have (another) bad batch of discs?(Which is what I thought happened when the Memorex wouldn't play.)
audio problems when burning a DVD
By cosypete in forum Authoring (DVD)Replies: 3Last Post: 9th May 2010, 19:23 -
Problems with DVD burning for backup
By DDieggo1000 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2009, 00:36 -
DVD burning problems
By Tbag in forum ComputerReplies: 13Last Post: 3rd Sep 2008, 16:55 -
DVD download Burning problems
By completeidiot in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 06:53 -
By ssaamm in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Sep 2007, 01:11
