Hello,
I've read some posts over time on this site regarding frameserving from VirtualDub to TMPGEnc, Is this a better method than simply importing your AVI files into TMPGEnc at whatever resolution they are in and selecting your final resolution with your TMPGEnc templates, and does doing it from VirtualDub save encoding time ? I'm satisfied with doing it the "old" way but also eager to learn any new tricks.
Any Takers??
Thanks, GMaq
With Virtualdub you can apply filtering and do some editting. Frameserving allows you to pass the video direct to TMPGEnc without saving to an intermediate file. By doing so you can avoid a re-compression step or avoid having to save a very large uncompressed file. So if you need to do some processing with Virtualdub then frameserving can be the way to go.
I just used Vdub to frameserve an mpeg1 file to TMPGEnc. The file had errors in it that prevented me from authoring and burning it as a VCD. Vdub allowed the bad frames to be re-encoded by TMPGEnc without losing A/V sync. For me it worked like a charm, but I wouldn't recommend it for most files unless you are having a problem."Art is making something out of nothing and selling it." - Frank Zappa -
ZippyP.
Thanks a lot for your obviously educated reply, Now I get it, no intermediate saving of your edited AVI, I'll have to give it a try for fun.
I usually do a direct stream copy after I've finished editing but this could save that step as well. Thanks again for your help. GMaq -
After you get the hang of that if you like it you should check out AviSynth.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
MKV to MPG2 AVI with VDub
By windranger in forum Newbie / General discussionsReplies: 2Last Post: 12th Feb 2010, 06:54 -
Can't framerserve vdub to tmpgenc under Windows 7 64 bit
By TheFamilyMan in forum Video ConversionReplies: 2Last Post: 8th Nov 2009, 18:29 -
Can't Frameserve to Tmpgenc
By BonnieW88 in forum Video ConversionReplies: 1Last Post: 30th Aug 2009, 23:40 -
How to frameserve this resizing algorithm to TMPGEnc?
By DRP in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 22:19 -
Frameserve from VirtualDubMod to TMPGEnc
By pchan in forum DVD RippingReplies: 1Last Post: 25th Aug 2007, 08:13
