History from www.mediachance.com
Can download from here:
http://www.mediachance.com/dvdlab/historypro.html
August 4th, 2004
Fixes from beta 6
- transitions for widescreen menus don't work correctly (always 4:3)
- movie without vts menu still CALLSS Root Menu in POST
- zoom out + F2 is messy
- force activate button should not be used if cell 3 in delayed menu exist
Added
- Intro Effect in Render Motion - create intro+motion that can be later used in delayed buttons menu.
- delayed menu cell 2 can loop or continue depending if the end link exist.
- objects in menu are now bit "sticky" when you click on them which prevents from accidental moving it.
- added delayed buttons feature to VMG
- if you use mpg file with AC3 stream or use mpg/vob and add more audio or subs the compile will first offer to demultiplex these files in order to be able to successfuly continue.
- if mpeg file has already PCI and DSI packets, it is then used as VOB during compile (to solve the audio problem on "DVD-ready" mpegs without demuxing)
DLP just gets better and better.
There is a reason why God gave us one mouth and two ears!!! -
This thread is misnamed.
The new beta is for DVD-lab Pro, not DVD Lab.
DVD Lab beta is 1.4, release version is 1.3.
help with DVD Lab Pro
By medo_256 in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2010, 22:02 -
DVD-LAB Pro 2
By Sanmaame in forum Video ConversionReplies: 4Last Post: 23rd Oct 2008, 05:42 -
dvd lab pro 2
By m baqar in forum Authoring (DVD)Replies: 6Last Post: 7th May 2008, 02:39 -
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 08:53 -
Q, for those who use DVD Lab Pro...
By GangstaRap in forum Authoring (DVD)Replies: 3Last Post: 1st Nov 2007, 07:15
