Dear Experts:
I purchased this dvd burner today, thanks for your patience and reading.
My system: AMD XP2600+
512MB PC3200 RAM
LiteON 812s (8x) (As Mater On 2ND IDE Cable End.)
I was burning Video files with a - 4x DVD disc. (file size about 4300MB)
and the process took about 40 mins to complete.![]()
(a friend said it took only 15 mins for the process, on same size of files)(Who also have the same DVD burner and same cable setting)
is this the problem with the burner or the type of disc I use ?
and Hpw does - disc difffer with + discs ?
thank you,
Kev
If you were simply burning files, that's too slow - check to see if DMA is enabled on your machine. If you were shrinking (transcoding) files, then burning, that time frame would be considered reasonable.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin
DVD Burning causes Extremly slow playback
By PowerFalcon in forum DVD RippingReplies: 4Last Post: 27th Aug 2011, 16:47 -
Dvd slow burning
By Psco2007 in forum Authoring (DVD)Replies: 29Last Post: 8th Dec 2010, 16:09 -
No audio when burning dvd using AVStoDVD (log posted)
By aikipaul in forum Authoring (DVD)Replies: 4Last Post: 4th Oct 2010, 12:15 -
slow burning samsung
By doctorrocco in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Jan 2010, 16:26 -
DVD ripping/burning very slow
By happy.hrvat in forum Newbie / General discussionsReplies: 5Last Post: 1st Apr 2008, 18:24
