did burn with tdk's now i am burning with prodisk white hubs. My burner can only burn at 2x but it feels ike 1x. I was burning at 30 mins but now it is an hour. Could it be my firmware? I checked my firmwareout and I can only find a update to make is regien free. My dvd burner is Toshiba SD-R5002
here is a link to my firmware.
http://forum.rpc1.org/dl_firmware.php?download_id=300
Mabye this is the a diffrent firmware then what i need?\
just did a search and found this
http://www.emediadepot.com/prodisc4xdvdrcompat.html
it says the prodisc can only write 1x with my burner. Is there a way to change that so i can wrote to 2x like a filmware?
if anybody can help me that whould be great
There is not much else you can do if there are no newer firmware updates for your drive.
You *could* attempt to hack the firmware and increase the speed to 2X for this media.
This would require a knowledge of the firmware code structure and a hex editor.
However, It could very well do you no good and result in unreadable discs...
If you want to burn at 2X you should probably just get rid of the prodiscs, and acquire media that you are sure are supported at 2X with your current firmware.WesleyTech.com - Blu-ray Disc & consumer technology news, reviews & articles
Help/Advise required...Toshiba V853UK VCR problems
By amtrakuk in forum DVD & Blu-ray RecordersReplies: 1Last Post: 1st Sep 2010, 12:48 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
Toshiba DVR610 tracking and video artifacting problems
By ministry88 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 29th Dec 2008, 11:46 -
Why is the Toshiba HD-A2 Better Than the HD-A3 ?
By ofield1 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 16:57 -
Problems with Toshiba laptop burner
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 11th Sep 2007, 00:42
