I have a wide screen Xvid I want to convert to SVCD, is there a way to keep the wide screen format, a certain aspect ration I should be selecting with TMPGenc?? Thank you.
Results 1 to 9 of 9
Source Aspect Ratio 1:1 VGA
Video Arrange Method: Full Screen (Keep Aspect Ratio) -
hmm, full screen (keep ar) never works for me. it usually causes the video to go outside the tv area.
what i like to do is use the center (custom size) and manually enter the size of the source. ***
***depending on the source size. -
Originally Posted by dafreak
sorry, but that's not how it's supposed to work.
I don't know about you but I like watching the video in its entirety, not 3/4 of it. If done properly, the viewable area will not be cut off, and without borders. -
not saying it's not doing what it's supposed to do. tmpgenc will encode it the way you ask it to, but that doesn't mean it's the correct way or how it's supposed to be done. I prefer not to do it this way
I encode a lot of anime, and if you encode using full screen (keep ar), the subtitles go below the screen and/or they will be cut off on the left/right sides. I prefer to see the entire subtitle and not just part of them. /shrug. to each their own. -
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
AVI to Xvid conversion
By Davjefdunn in forum MacReplies: 4Last Post: 16th Sep 2009, 09:48 -
Intermediate codec and xvid question, and xvid to wmv.
By ^xRun^ in forum Video ConversionReplies: 9Last Post: 22nd Jul 2008, 17:13 -
Help with conversion to Xvid
By zovx in forum DVD RippingReplies: 2Last Post: 6th Feb 2008, 15:32 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11
