i am trying to convert divx and xvid into dvd files but i am having problems
i am using the guide by baldrick
https://www.videohelp.com/forum/viewtopic.php?p=994738&highlight=baldrick#994738
i have installed all the correct progs that go with this version in the guide
in the diko prog you go to configuration work your way through using his guide , when you have done everything and try to go to the next stage i get
ERROR SAMPLE SIZE FACTOR MUST BE GREATER THAN !!! SMALLER THAN !!! BUT MINE READS 0.000 AND YOU CANT CHANGE IT ITS BLOCKED OUT
does anyone else use d i k o that can help or can anyone suggest different progs that can convert divx , xvid , vcd , svcd , into dvd files so i can burn to dvd that will work on any dvd player
Results 1 to 1 of 1
Encoding with diko
By djgazzabhoy in forum Authoring (DVD)Replies: 2Last Post: 13th Dec 2010, 05:49 -
Question about DIKO
By Belfour in forum Authoring (DVD)Replies: 7Last Post: 6th Aug 2008, 01:27 -
Error using diko
By thecrock in forum Video ConversionReplies: 4Last Post: 24th Apr 2008, 17:55 -
How to make DIKO files into DVDFiles ?
By Locutus666 in forum Authoring (DVD)Replies: 17Last Post: 4th Nov 2007, 04:31 -
DIKO for dvd burning
By wristar in forum Authoring (DVD)Replies: 1Last Post: 29th Oct 2007, 14:41
