I recently had an AMD Athlon 2200XP in my computer. I had the 166S ripping in just under 20 minutes. I just updated my processor to a P4 3.0 Ghz. Now when I try to rip it takes 50 min!! I have the latest firmwares and DMA is enabled any ideas?
Results 1 to 13 of 13
Go here:
http://codeguys.rpc1.org/firmwares.html
and read the instructions carefully and get the hacked firmware that will increase the speed of a read. My drive reads a full DVD9 in 11 minutes.Still a few bugs in the system... -
I went there and installed the firmware but its still ripping really slow. I am trying to rip a single sided DVD and its taking 45 minutes now. Still no luck
does anyone know where to get firmware for NEC ND-2510A its bout 45 min for a rip pretty slow
make sure you have the jumper on the drive correctly set to master or slave. what firmware did you install?
Have you tried all the suggestions in the DVD Ripping Speed Tips sticky ?
If in doubt, Google it. -
I installed the 166S.DS1C.patched-rs16xR_16xRW_10xDVD9 firmware. Looked at my secondary IDE, it says DMA if available but under current it had PIO. And I cannot chage this, any ideas?
ok I figured it out... turns out what I needed to do was uninstall my secondary IDE. Then restart. After that the current transfer mode was set to Ultra DMA. Thanks for the help all.
After few unsuccesful UDMA attempts Win XP will downdrade permanently IDE channel to PIO (standard feature). What you did was right on the money. The only way to reset to default is to uninstall and reboot.
The hacked firmware only improves reading/ripping speeds for dvd r/rw discs and not commerical pressed discs which i think he is probably talking about, right?
Originally Posted by vdk_au
http://codeguys.rpc1.org/firmwares.htmlStill a few bugs in the system...
Fast/reliable drive just for ripping?
By wetcamelfood in forum Newbie / General discussionsReplies: 4Last Post: 11th Nov 2011, 01:07 -
Problem ripping a movie to avi with AutoGK, fast motion audio/video
By Mr. SoAndSo in forum DVD RippingReplies: 1Last Post: 7th Oct 2008, 11:57 -
Problem ripping a movie to avi with AutoGK, fast video/audio
By Mr. SoAndSo in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2008, 11:54 -
Need a fast ripping dvd burner with lightscribe
By hellbringer in forum DVD & Blu-ray WritersReplies: 7Last Post: 13th Nov 2007, 20:46 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 20:43
